Chrome vs Stock Browser in Note 3?
I found this thread after I Googled the same question.
I have used Chrome on my last 5 devices. One thing I can't stand about it that makes me think of just sticking with the stock on my new Note 3, you can not set Chrome to download to the SD card, I dunno why Google hasn't made this a feature yet.
Depends upon your need. If you are using Note 3 then most of Note 3's stock features including S-Pen integration will not work which limits the functionality of your Note 3 Experience. If you want to use your Note 3 as a smartphone only and you don't have much utility or need for its SPen features then you are better off with Chrome. In fact, you don't even need to own a Note 3 if SPen is not for you. Else the stock browser. The only limitation of the Stock Browser is that it does not 'Whispersync' your history, log in details and bookmarks in real time across your other devices. Not sure how much of an issue this is for you.
I too prefer Chrome. I like how I can see what's sync'd on my other devices that's also running Chrome.
Sent from my VZW Samsung Note 3
Doesn't the stock browser also sync your chrome bookmarks... I have went back an forth at first then shut off stock browser (root) but I find actually it has benefits over Chrome b/c you can w/o using the "read" mode turns **** yellow, still tap the green R in addy bar to ez read as big as you want an only affects that session of browsing. Hope this helps someone
Heritagesa01
