Circle widget
Is there a different recovery that may work instead ?
---------- Post Merged at 10:54 PM ---------- Previous Post was at 10:53 PM ----------
it says safestrap-1.0apk
Wah ditch that, you need the new one. Restore your back up in safestrap and install the new recovery
Sent from my RAZR MAXXIMUS ;)
Not sure if it works, you may have to ask over at droidrazr.com I think they are fixing it in the next release
It's working now for some reason.But now I'm getting this repeat text every 30 min to a hour that says VZWNMN:2 what is this ?
You have to go to my Verizon on your computer and disable backup assistant plus and it will fix that if I recall correctly
Finally got it working. But the calendar isnt working. Is that common?
Sent from my DROID RAZR using Android Central Forums
The calendar for me is working.
I'm loving this rom!
We need this circles widget to be put out as an individual app (no root required). I'm sure someone can do that!
opegamani
