"Circles" Widget Missing
Thank you for your solution. That happened to mine this morning (don't know how), and I tried several other solutions, but yours was the one that worked.
HOW do I get this Circles widget to stop notifying me of answered text messages and unanswered phone calls, etc. ???
Nevermind. Found answer. The setting are accessed by flipping the battery icon
I have a new phone, prev died. Moved the droid command center toward the top and bang! it was gone.
Followed all here,see it it running under "apps" but cannot get it to show back on screen. I also have NO "widgets" tab anywere. NOT running latest crappy Android update either, crashed prev. Phone. Any ideas how to get it back? Tried tapping, holding, dragging, swinging dead cat over my head!! LOL Helps me please mr. Wizard!
Mark
I have a similar issue but when I try to reload widget, it tells me it is already there. Does not show up in apps on settings. What next?
I have the same problem did you find a solution? UGH VERY IRRITATED!! BECAUSE I DON'T SEE IT ANYWHERE ELSE!!
FINALLY FOUND IT!!! IT WAS OVER to the LEFT!! IF YOU SCROLL LEFT PAST AMAZON IT WAS THERE ON A BLANK PAGE I DIDN'T REALIZE HAD BEEN MADE!!
Home is the first screen that pulls up. Place and hold finger on screen, then select "widget". Select the widget that has disappeared by moving it to the home screen.
Beboomo
