Cleaning the nexus 7 screen
Just used dish soap and water and I'm surprised how well it worked. Windex makes an electronic flavor cleaner, prolly try that next time I need a clean. Dave is right, no need to be paranoid.
You can use rubbing alcohol to clean the screen with a cotton ball. Its a cheap solution and works very well, I use it on my s3.
Sent from my SPH-L710 using Tapatalk 2
elowen89
