Clockworkmod Recovery for Xoom?
Yes, Titanium seemed to back everything up just fine. I did not, however, try restoring. But I don't see why it would not work. Did you get an error or something?
Yeah, it seems to be acting up. If I select restore app only, it says it succeeds but nothing happens. If I restore App+Data, it says it fails. I've tried changing the App Processing mode but it either gets stuck or fails. Some other features like detach from market don't seem to be available as well. I tried using the busybox downloaded from within Titanium Backup itself, but it didn't help.
Looking at adb logcat, I guess there is some problem.
Code:
D/AndroidRuntime( 5058): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
D/AndroidRuntime( 5058): CheckJNI is OFF
D/AndroidRuntime( 5058): Calling main entry com.android.commands.pm.Pm
D/asset   ( 4999): failed to open Zip archive '/data/data/com.keramidas.TitaniumBackup/files/install.apk'
W/PackageParser( 4999): Unable to read AndroidManifest.xml of /data/data/com.keramidas.TitaniumBackup/files/install.apk
W/PackageParser( 4999): java.io.FileNotFoundException: AndroidManifest.xml
W/PackageParser( 4999):         at android.content.res.AssetManager.openXmlAssetNative(Native Method)
W/PackageParser( 4999):         at android.content.res.AssetManager.openXmlBlockAsset(AssetManager.java:487)
W/PackageParser( 4999):         at android.content.res.AssetManager.openXmlResourceParser(AssetManager.java:455)
W/PackageParser( 4999):         at android.content.pm.PackageParser.parsePackageLite(PackageParser.java:602)
W/PackageParser( 4999):         at com.android.defcontainer.DefaultContainerService$1.getMinimalPackageInfo(DefaultContainerService.java:138)
W/PackageParser( 4999):         at com.android.internal.app.IMediaContainerService$Stub.onTransact(IMediaContainerService.java:100)
W/PackageParser( 4999):         at android.os.Binder.execTransact(Binder.java:320)
W/PackageParser( 4999):         at dalvik.system.NativeStart.run(Native Method)
D/dalvikvm( 4999): GC_EXPLICIT freed 25K, 6% free 6195K/6531K, paused 1ms+2ms
W/DefContainer( 4999): Failed to parse package
W/ActivityManager(  119): No content provider found for:
D/dalvikvm(  119): GC_EXPLICIT freed 534K, 38% free 18084K/28935K, paused 3ms+5ms
D/AndroidRuntime( 5058): Shutting down VM
D/dalvikvm( 5058): GC_CONCURRENT freed 205K, 87% free 348K/2560K, paused 0ms+0ms
D/jdwp    ( 5058): adbd disconnected
I/class com.keramidas.TitaniumBackup.c.k( 3463): App installation activity has finished ! (resultCode = 0)
No idea what file it's referring to, it doesn't seem to exist on my Nexus S either. Guess it's just some incompatibility with Honeycomb.
I hope nandroid works better, I haven't tried restoring a backup yet :p
Jon OapostraphyBrien
