CM10 and MMS issues
corolla90
266
Anyone having issues with MMS in CM10 nightlies? I'm running the latest, and whenever I get an MMS, it stays stuck in "Downloading" mode. And then I never get it. I'm surprised this is still broken, considering JB has been officially release for NS4G. Anyhow, just thought I'd inquire and see if anyone has info on this being fixed or a workaround. Thanks!
Yeah, I've experienced this issue but sporadically. Not all the time... Odd!
And I'm NOT on CM10
Please post this bug here: https://code.google.com/p/android/issues/list (So Google can know about and fix the issue)
I would recommend codename android. I've been running it since yesterday and have sent/received multiple picture messages without issue. It also has working SMS split and is fast. I have yet to run into a FC, reboot, freeze, or any problem like that
Sent from my Nexus S 4G using Android Central Forums
Same issue here. I'm running the latest CM10 on the galaxy s3 from at&t. I was connected to WiFi And wasn't receiving 4g service. Try disconnecting from WiFi and run the app "fresh network" after that your signal should improve. Then ask to resebd the MMS. Its only a quick fux , but try it and see what you think.
Pickle240
