CM7 issue please help
94v6kid09
11
hi im new to the site and just rooted my first android with the one step that i found on here
very easy btw
well i decided on cm7 for my custom rom and now I dont have the android market whats up with that
i had titanium back up pro but dont know how to access it from cm7 rom
please help
i would like to be able to restore my contacts
very easy btw
please help
Use this lnk to get gapps and then flash in recovery http://android.d3xt3r01.tk/cyanogen/gapps/gapps-gb-20110613-signed.zip
well it looks to be doing the right thing we will see in a bit
just rebooted
yup it works fine thanks
I have everything up and running but it seems to have a horrible battery life now I turned off the gps any advice on how to optimize?
Try wiping the battery stats.. that could let your phone start fresh.
Also, I had terrible battery life for awhile, then i realized one of my email accounts was syncing every minute. (dumb me)
Make sure that you set your email accounts to push, or whatever length of time you want to have between your syncs.
Also, I foudn this out, if you have a ton of widgets, like for tapatalk, twitter, etc running, those are going to zap your battery life. Make sure to decided which widgets are important to you, and which ones you dont need.
IN regards to "kernel", a kernel is part of the progrmaing of the phone that can tweaked. there are some kernels "leankernel" (try googling it), that i know work on OTHER ROMs. I had no need as of yet to flash a kernel. Althought I would be interested to see if anyone out there has any imput on that.
what is a good reliable rom i dnt much care for the cm7 now im not sure why but it seems my youtube and internet are affected by it
le_stan
