cm7 nightly available now
If I install the internal version of CWM, how do I boot up into recovery on to the internal CWM?
the power > reboot > recovery option doesn't work
I use ROM Manager.
1) install CWR from the before mentioned thread.
2) install ROM Manager
3) open ROM Manager but DO NOT flash the current version of CWR (3.0.0.5)
4) hit reboot into recovery
it should fire up in 3.0.0.6...
even backups work for me via Rom Manager.
Reactions: bravebull
OK... since I wasn't smart enough to avoid the "DO NOT flash" part of this, can I delete rom manager, use my SD card to boot into CW, then flash 3.0.0.6, reinstall rom manager and then avoid the flash part as mentioned in digitalslacker's post?
That is pretty much what I did after reading his instructions. I had previously flashed from within Rom Manager. As stated above, working great.
CM7 rules. I'm currently running nightly #3 and it blows away the versions of Eclair, Froyo and Honeycomb that I've tried.
I really liked the Honeycomb GUI but the preview version is too buggy to use as a daily driver even running off EMMC, especially when CM7 is lightning fast and more functional at the same time. I expect that once the final version of Honeycomb is released, that will rule all.
Install was a breeze, was a little worried when the screen didn't want to turn back on at first, but then it popped right back up. The odd thing now is, it won't connect to my router. Had no problems with that before CM7. It will tether to my Droid X no problem, but even after putting in the password for my router, it just tells me it's remembered, and refuses to connect. I've even rebooted the Nook, and same thing. Router is obviously working, sending this message through a netbook connected wirelessly to it, and was playing Black Ops on Xbox 360 while downloading the CM nightly. Will reboot router and see if problem persists.
Okay guys i am TOTALLY LOST. I rooted my nook awhile back but i cant for the life of me figure this out. My EVO has CM7 but im lost. Cant find instructions on any site that i understand. Can i paypal someone to turtor me through this? Should i shake chicken blood on my nook while dancing around it?
See this post on XDA--everything up to step 20 should be what you're looking for. A slightly older version of this without the steps at the end is what I used to get CM7 working on my Nook Color.
xda-developers - View Single Post - [USER] CM7 General Discussion thread
gamersOnedge
