Cold As Ice working on Optimus V!
The battery on Cold as Ice is unbelievable, holy s*** I can't believe it's been unplugged for the past few of hours and it's still on 100% :o
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
That's probably not a good idea, as both roms CAN have a different framework.
Well i didnt use the entire framework folder man just the one file. I was also told to do it by another dev on here so I assumed it was common practice.
Who has a working camera with preview? This guy!
Expect to see an update soon:)
don't expect anything he's a hard working dev that doesn't even have to continue this rom so be patient he could take as long as he likes several years if he wants so be patient you will eventually get an update
Sent from futuristic optimus s
sorry i should be more specific my su isnt working properly on this rom or quattrimus is this a cm9 issue, is it turn off or blocked because these roms are alpha, or is it just me??
One thng i noticed that this rom is LEAN!! I installed all my normal apps then moved to sd card and only used up 25 mb!
Sent from my LS670 using Tapatalk 2
I really want to try this right now :P So i flash alpha 10.. then gapps and then what? Im confused
Willing to give out some thanks for the answer ;D
Alpha 9 cold as ice is very very fast and stable alpha 10 just has camera preview
araelbenjie
