Connect Note 5 to samsung gear s
Turn Bluetooth on ur phone...install Samsung Gear app...press sync...it'll give u a code on each device u press ok n ur good to go
If you had the gear s connected to a different phone before the note 5, you'll likely have to 'factory reset' it before connecting to the note 5. I had to do that and another person did as well when I posted in the forum.
And yes, it will force you to reset the Gear S before it will pair with the Note.
Posted from my Galaxy Note 5
clive
