Connecting ANS UL40 to Windows 10 using a USB cableWindows 10 using a USB cable
  • Start date Start date
A
Android Central Question
I haven't used my UL40 Android Phone for some time which was replaced with another one.
I went through this before trying to get into the UL40's USB settings through the pull down menu.
However the USB settings have seemed to disappeared. I'm using another usb cable. Perhaps I need another usb cable for the UL40's USB setting to re-appear?
I'm finding settings from the pull down menu which doesn't appear the same as with my previous UL40.
Do I need to be connected via a usb cable to a PC for the UL40's USB settings to appear?
Welcome to Android Central! USB cables can fail -- try a different cable and see if the USB notification icon appears in the swipedown menu then.
wilderjohn7
