Connection problems--HELP.
Thorben Janssen
my infuse worked just normal until today.
It started off with the touchscreen being uresponsive for a couple of minutes.
Now it will not connect to my computer ( unrecognized device) and the connection symbol in the notifications bar on the phone is not coming up either.
Furthermore it will not ncharge, not withdifferent chargers or USB cables. It only charges when it is turned off, then connected to the charger and then turned on. So a hardware problem seems unlikely to me.
I updated it to 2.3.5 over KIES (which was an awful idea anyways)!
Any help would be greatly appreciated.
only with respect to your connection problem. First, check if the wifi connection is "On" to detect available device and that your computer's wifi is "On". As much as possible, have at least two network/device where you can connect. If none of the available networks are listed, there is a problem with your phone's reception. If there is an available network, connect to the network. You can also try to set-up a network to detect available networks, check this link for a guide Internet mobile connection problem android | Techyv.com
jenleasch12683
