Considering Razr Maxx HD
Is it safe to assume Motorola wont be releasing a new updated phone in the next few months? I'd sure hate to make a purchase only to see new new one hit the shelf in the next 2-3 months.
I have three Smart Actions that I use and I have been using 4g on my phone. I can go from 6:00am to 1030pm with at least 60% plus battery every day (usually it's more than 60%):
1. Trigger - Display Status (Off)
Actions - Mobile data (Off)
2. Trigger - Location (My house)
Actions - WIFI (On) <-- to counter this one I downloaded an app called WIFI Powersaver to turn WIFI back off after one minute of not being connected like for when I leave home.
3. Trigger - Timeframe (2230-0500)
Actions - Mobile Data (off)
Airplane Mode (on)
Display sleep (15 seconds)
Brightness (Smart brightness)
WIFI (Off)
GPS (Off)
Do you need the WIFI Powersaver app? It thought it seemed as if Smart Actions turns the wifi off for you when you're not at the trigger location anymore. It's hard for me to test because I get on the subway a lot when I leave home.
Yes. I thought the same thing when I first got the phone so I only did the Smart Action to turn it on. I started noticing my WiFi was on after I left home and continued to wait to see if it might take a little time to turn off but it never did. Same thing happend on my wife's Maxx and my daughter's M. Then I tried the Y5 Battery Saver app because it worked great on my TBolt but it didn't seem to work so well on any of our phones. So I just use the Smart Action and the app and they both work great.
GiftedWeeTodd
