Constant red notification light...help
ihbsbA
1,417
5
Ok, what's up with the red light on the Replenish? There are no notifications - no missed calls.....what does it mean when this light is on and doesn't blink?
There's been an LED light bug for a couple phones for awhile now. An update was pushed out today. If it notifies "System update available," try it. It's a small update for a few fixes. I haven't applied the update myself, so I don't know if it will help you. Updates are usually a pretty good thing though, so it wouldn't hurt.
Reactions: ihbsbA
Here is the fix for this issue: The red LED light stays on when the phone is unplugged from the WALL before it's unplugged from the CHARGER. Always pull the phone off the charger while plugged into the wall. Easy enough - took me 3 phones to figure it out.
khizarhayatt
