Contacts default led color (how to change)
Just_Some_Nobody
236
When i go into contacts, select a contact and scroll to bottom it shows the default notification led color. How do I change that per contact? I tap it but nothing happens.
Note: I'm not using at&t contact sync but sync contacts through google if that helps.
You have to edit the contact by hitting the little pencil icon.
Sent from my LG-D800 using Tapatalk 2
