Contacts not syncing with assigned group. Please help
Status
Not open for further replies.
keystone_56
89
Hello, I am having a problem syncing my Gmail contacts after doing a factory reset on my GS7. The contact name, number, and email all sync up fine. But the group classifications are gone, each of my contacts are assigned to a group. For refrence, I have the same account/contact list on my business phone (note 4) and the group assignments are still correct. On my desktop these groups have also been stripped off at some point. This has had to occur recently because I switch devices every month or so, and this is the first problem syncing. So I have to assume my business phone (note 4) is the problem. Under settings I'm not seeing any sync errors at all on either device. Any advice?
First option is reboot. try to reboot then its only because of your setting go and check out in settings . sync setting check out if there is any option checked or unchecked. or some times if phone's ram is then it also do this thing so try to flush out temp files and release ram's memory
I have already tried restarting, powering down/up, and pulling the battery on the note 4. Any other ideas?
Further examination reveals all communication is working other than the Note 4 sending group info. For instance if I make a change to any other option on a contact card other than the group assignment, then that info is synced to both my other devices and the the contacts online. If I make a change to the group settings on the note 4 that info is not synced online or on my other devices.
Any change get made online or on my other devices are 100 percent synced when I view the specific contact on the Note 4.
Status
kimlien
