COT v2.0 Optimus S, V, M post design
drewwalton19216801
2,476
2,803
Team Hydro presents....
Cannibal Open Touch v2.0 for LG Optimus S
About Cannibal Open Touch
Cannibal Open Touch is the next generation of custom recoveries. Jam-packed with cool and useful features, it can handle just about anything you can throw at it. Main Features: 1) Support for both Edify and Amend scripting (flash all ROMS!) 2) Theme support 3) Get out of recovery boot loops 4) Touch screen button controls! 5) Compatibility with Xionia nandroid backups (if on LG Optimus device) 6) GooManager support! 7) Internal e2fsprogs for size 8) Backported “retouch binaries” patch for ICS/JB compatibility 9) Advanced Backup 10) Delete old backups! 11) Persistent settings Why the name Cannibal Open Touch? Because we can. The name also embodies everything that Cannibal Open Touch is. It is no longer just a variant of ClockworkMod Recovery, it is it's own recovery by itself. Combining features from ClockworkMod 5, Team UtterChaos' Sony Xperia recovery, AmonRa 3.0.6, Xionia CWMA and a bunch of our own special enhancements it is truly revolutionary.
[INFO]What to do when an error occurs:
DO NOT simply say "xxxx doesn't work" as that is very very unhelpful and will probably be ignored. Instead, post the recovery log! To grab a log when an error occurs, simply open a terminal (or command prompt if on Windows), "cd" to an easily accessible directory and execute:
Code:
adb pull /tmp/recovery.log
Paste the log as an attachment (don't paste the text inside, as it can be very long).[/INFO]
Flashing Instructions
1) Make sure USB Debugging is ON and that you have ADB access 2) Download the Cannibal Open Touch image 3) Place the recovery image on your SD Card. 4) Fire up an ADB shell 5) Make sure you are in a root shell. If you are not, execute the "su" command now. 6) Execute "flash_image recovery /path/to/recovery.img" (replace /path/to/recovery.img with the ACTUAL path to the recovery image) 6a) If you get a "command not found" error with the above command, STOP! Download flash_image (mirror), extract flash_image from the ZIP that you just downloaded (and copy it to the top level of your sd card, and follow the first three commands in the Xionia Recovery instructions. Once you have flash_image installed, do step 6 again. 7) Reboot to recovery mode 8) PROFIT!
Already have a custom recovery?
1) Download the ZIP installer from the downloads below 2) Reboot to recovery 3) Flash the ZIP installer as you would a ROM or Kernel (that is, flash it from recovery) 4) PROFIT!
Main Recovery Screenshots
Available Themes
Download Cannibal Open Touch v2.0
[WARN]Warning: Due to major core changes in the Nandroid software, any Nandroid backup made with CWMT Recovery 5.0.2.7-th7 will not be able to be restored with any other version of this or any other recovery. Please make a fresh backup immediately after flashing Cannibal Open Touch. Xionia backups should be unaffected.[/WARN] [INFO]Cannibal Open Touch Handbook: Because so many things have changed since Cannibal Open Touch v1.2, we have created a handy little guide (a "handbook") to help you become accustomed to the features and menus of Cannibal Open Touch. This guide is available as a PDF document, so you must have a PDF reader installed. Download the guide here (PDF, 183.2 kB)![/INFO] By clicking any of the below links you agree that you are flashing this recovery image at your own risk. Neither myself, Team Hydro, nor anyone but yourself are responsible for any problems that may occur before, during or after flashing this recovery image. You also agree that this recovery image is to be flashed ONLY on the LG Optimus S, and not any of the other LG Optimus variants. Download | Mirror | Alternate ZIP installer MD5 Info: Recovery Image: 003404971d2bfea76f5f25bbd53b1286 ZIP Installer MD5: 57a742afcf5cca925cc5b74653cf3317
Known Issues
None!
Changelog
v2.0: Optimus M support, themes change immediately (no reboot needed), file-based settings framework, rewritten theme framework, removed a bunch of dead code, initial multi-language framework (incomplete), OpenRecoveryScript optimizations, fixes for using GooManager in a Jellybean/CM10-based ROM v1.2: Advanced backup, nandroid backup prompt on installing ZIP package, nandroid backup fail on low space, delete old backups, now flashes all ROMs v1.1: ORS patches, Advanced menu reorganization, retouch patches, internal e2fsprogs, fixed sd-ext restores v1.0.8: Fixed signature verification, now enabled by default v1.0.7: Fixed OpenRecoveryScript support v1.0.6: Enabled OpenRecoveryScript (GooManager) support (broken) v1.0.5: Fixed vertial touchscreen boundaries v1.0.4: Fixed "power off" menu item v1.0.3: Fixed "file not found" error v1.0.2: Colorific theme engine updates v1.0.1: Fix build.prop to workaround CyanogenMod's erroneous use of asserts. v1.0: Initial release! Previous versions: CWMT Recovery 5.0.2.7-th8.1
Source
Want to see what we're working on? Follow the bitbucket source repository! https://bitbucket.org/drewwalton19216801/cwmrecovery-teamhydro
Special Thanks
Koush The CyanogenMod Team All of Team Hydro Cory Streater, for tolerating (I hope) the Dooderbutt Jerry Hildenbrand and Beezy, for starting the Dooderbutt revolution AndroidCentral Team Utter Chaos, for the kick-ass touchscreen buttons sblood86 (much of COT would not be possible without him!)
Cannibal Open Touch v2.0 for LG Optimus V
Code:
Available Themes
[WARN]Warning: Due to major core changes in the Nandroid software, any Nandroid backup made with CWMT Recovery 5.0.2.7-th7 will not be able to be restored with any other version of this or any other recovery. Please make a fresh backup immediately after flashing Cannibal Open Touch. Xionia backups should be unaffected.[/WARN] [INFO]Cannibal Open Touch Handbook: Because so many things have changed since Cannibal Open Touch v1.2, we have created a handy little guide (a "handbook") to help you become accustomed to the features and menus of Cannibal Open Touch. This guide is available as a PDF document, so you must have a PDF reader installed. Download the guide here (PDF, 183.2 kB)![/INFO] By clicking any of the below links you agree that you are flashing this recovery image at your own risk. Neither myself, Team Hydro, nor anyone but yourself are responsible for any problems that may occur before, during or after flashing this recovery image. You also agree that this recovery image is to be flashed ONLY on the LG Optimus V, and not any of the other LG Optimus variants. Download | Mirror | Alternate ZIP installer MD5 Info: Recovery Image: f320533469e20db5abf19eb4dcff6fae ZIP Installer MD5: dad80862a07c5479c3d8ab976f73bef9
Known Issues
None!
Changelog
Source
Special Thanks
Cannibal Open Touch v2.0 for LG Optimus M
Code:
Available Themes
[WARN]Warning: Due to major core changes in the Nandroid software, any Nandroid backup made with CWMT Recovery 5.0.2.7-th7 will not be able to be restored with any other version of this or any other recovery. Please make a fresh backup immediately after flashing Cannibal Open Touch. Xionia backups should be unaffected.[/WARN] [INFO]Cannibal Open Touch Handbook: Because so many things have changed since Cannibal Open Touch v1.2, we have created a handy little guide (a "handbook") to help you become accustomed to the features and menus of Cannibal Open Touch. This guide is available as a PDF document, so you must have a PDF reader installed. Download the guide here (PDF, 183.2 kB)![/INFO] By clicking any of the below links you agree that you are flashing this recovery image at your own risk. Neither myself, Team Hydro, nor anyone but yourself are responsible for any problems that may occur before, during or after flashing this recovery image. You also agree that this recovery image is to be flashed ONLY on the LG Optimus M, and not any of the other LG Optimus variants. Download | Mirror | Alternate ZIP installer MD5 Info: Recovery Image: b84375664197a431a518b251fd6f698a ZIP Installer MD5: 1dd0b6397071efcc8b58e8b66540fc1b
Known Issues
None!
Changelog
Source
Special Thanks
[TIP]Easter Egg Competition!
Cannibal Open Touch v2.0 contains an easter egg. If you find it, don't give it away! Rather, send an email to happyeaster@teamhydro.info with your AndroidCentral username, a description of what you found, and the steps you took to find it. If you can, please also provide a screenshot (Android Screencast can do this).
Submitters who have correctly identified the easter egg contained in Cannibal Open Touch v2.0 will be entered in a random drawing. The prize? Help us create a new Cannibal Open Touch theme! The drawing date is to be announced, so check back here often!
Rules:
1) Beta Testers are not eligible!
2) If you think you found the easter egg, do not discuss it with anyone!
3) This is for fun! So don't feel bad if you don't find it and/or don't win!
Hints:
There is one hint: in order to find the easter egg, one must do something a certain number of times in a row.[/TIP]
Mangcakok123
