Couple issues with GoSMS Pro
TheMatrix31
286
6
Hey guys,
So I'm encountering a couple of weird things while using this messaging application.
One, if I take a picture and try to send it out as a message directly from the gallery, it'll hang while sending. The outward mail icon just stays there as if it's going, but nothing happens.
I have to instead go into the program directly, and attach it manually. And when I do that, it doesnt show the receiver the pic, but rather a link to view the pic.
Anyone know what's up?
Reactions: brybry2
I noticed the same thing, not sure what is going on.
I work around it by opening up the stock HTC messaging app and sending the pic from there. Its not a big deal for me since I don't send MMS very often.
Hmm, weird. Perhaps a fresh install would fix it. Or I can just go into the regular messaging app to send pics.
If only the damn phone would light up with incoming notifications (instead of just the LED) for the stock app, I wouldn't even need this GoSMS stuff.
Go SMS Pro looks really good! I am going to be downloading it soon to play around with it here and there! I will report in with what I find with my phone.
If you're getting a link, you're sending it via a different method.
if it's hanging.... are you connected to wifi while doing this? I had this problem, and had to resort back to the stock msg app.
My issue is with the led blinking, even after the message pop up box has been closed, and the message has been read.
Same here. I find that pulling down the notification bar then closing it again makes it stop, even though there's no actual notification left in the list.
Yeah it's over wi-fi. But it sends just fine over wi-fi if I attach the picture manually and not do it straight from the gallery.
+1
I just deal with it unfortunately :-\
I have discovered an issue with GoSMS as well. I am using a custom vibration pattern. If the app is open, even with the screen off, the custom vibration is not played. If I close the app (go back to the home screen) then the custom vibration is played. Has anyone else noticed this? Any fix?
urlacherjer
