- Sep 23, 2014
- 57
- 1
- 8
Just updated to 10 and when my volume is set to max it's cracking. Never had this issue until the update today. So it's not hardware related. Just wanted to see if anyone else is experiencing this as well.
I just tried it listening to something on Google Play Music, and at maximum volume I found some cracking as well. Certainly not noticed previously.Just updated to 10 and when my volume is set to max it's cracking. Never had this issue until the update today. So it's not hardware related. Just wanted to see if anyone else is experiencing this as well.
I'm just wondering what is the easiest way to report this to Google?At least it seems like a software problem and not hardware related. Now I just have to remember not to crank the volume all the way up.
Maybe your just needed a restartI contacted Google support, and they had me reboot in safe mode. I checked volume there, and all seemed to work fine. I then rebooted into normal mode, and the volume issue seems to be resolved. Easy fix.
To reboot in safe mode, hold the power button and hold the power off button until it asks you if you want to reboot in safe mode. Just restart it again to get back in normal mode. Hope this works for you as well!
When I try troubleshoot my devices, I go with easiest steps ,reboot the phone lol lot of times fixes little glitches.Could be...
