Custom boot animation problem.
mac_hack_420
18
Hi i have encountered a problem whilst trying to change my boot animation, I made a back up before I started. I downloaded the relative zip files and flashed them using twrp which installed them fine. It was only when I rebooted it didn't work the Samsung sound still played but no new boot animation. I also encountered a whole bunch of system errors so rebooted to recovery and re flashed my rom and everything is fine.
Is there another way to custom my boot animation.
Sent from my SM-N9005 using Tapatalk
I believe part of your answer is already answered.
You have to be running a custom kernel that is capable of custom boot animations.
From what you have said it sounds like your stuck in a bootloop. I hope you made a full nandroid backup before you flashed anything. If so boot into recovery and wipe dalvik cache, cache and data. Then restore your back up. Hope this helps.....
Musliman
