Custom CWM for P505 & P506 Colors Fixed
I just wanted to mention that i cant flash any roms with this recovery :( ill uload a pic of the error im getting.
Yeah that is a definate a problem What baseband and OS are you starting from. Can you send a log file? Can anyone else verify this issue?
likey to do an assert failure, not a problem with recovery. Either update the updater-script in the zip you're trying to flash with the proper name or remove the assert check.
Um sorry....im kind of a noob, how do i do that?
It has to do with the ROM you are trying to install. Some ROMs will need to be recooked in order for us to use them others will work just fine. Anything that specifically states in the code that it was developed for the P505 like the offical CM7 builds will likely break but I did have luck flashing perfect pesto to my phone (though the rom hung, probably a kernel issue. it did flash without error)
How were the colors fixed? If i could find out what had to be done i could probably just build a p500 kernel with the color fix and we might be able to use it?
Reactions: AdictoDigital
Megafrost
