Custom image on Always On Display?
The AOD upgrade is in the About Always On: Settings > Phone > Display > Always On Display > About Always On Display.
You're welcome
The below is from the Batman logo guy haaaa!
Go into the Always On Display section in settings. At the bottom click ABOUT ALWAYS ON DISPLAY. Make sure it is version 1.7.29. if it isn't, it should give you an option to update it right then and there. If you are on that version, go to LAYOUTS, Content to Show = CLOCK, and then scroll to the very last one on the bottom. That AOD lets you use your own photo. :-)
How to update always on display.
Wish I hadn't come in here. I knew about this feature as I helped my wife set it up on hers. She also liked that she could change the color of the text on the screen. I ended up putting the daily events calendar on there because I always seem to forget about meetings at work till the 15 minute reminder goes off and sometimes I am more than 15 minutes away. But this thread is making me want a picture.
How come yours is so bright and mine is so dull?
I noticed this issue a lot when I first got the phone that sometimes my aod was dull. And the notes I would pin to it were duller than the rest of the display. It for the most part seems to be fine now, but I just saw my wifes do it today and as far as I know she hadn't had that problem before.
The AOD auto dims like the normal screen depending on how bright conditions are around you when the screen turns off.
This is my AOD.
In my options, I only have Version 1.3.14 and it said my phone is up-to-date. There is no updates for the phone in settings neither.
cinemacritic
