custom notification problem
cor leone
3
Hello
I have problem with setting custom notifications on my Honor 50 with android 11. I can’t set it for viber notifications or for specific contact (default app for phone contact).
When I choose notification sound it shows blank select sound window for part of a second and than it goes back to app.
Please check video and photo.
https://www.dropbox.com/s/h05zcge13o413pl/android%20notifications.mov?dl=0
https://www.dropbox.com/s/1vdcr1wi5vkprfa/android%20custom%20ringtone%20problem.png?dl=0
Welcome to AC!
What if you long press the app then tap info>notification categories tap >each sub menu tap to change the sound notification?
Where did you download the notification tone ?
Make sure you put them in your Phone File manager folder under notifications
Hi Mustang
Thanks for quick reply.
If I long press I don't get info it only show last contacts on viber and fauvorites, new contact etc at contacts. Should I change any setting?
I put notifications tone to notifications folder. But I can't even choose defaults one from the phone. Can't even open setting as you see on video.
Hi Mustang
Oh wow not even the default ones ,try safe mode but it will turn off 3rd party apps but u can try phone app
Nehasingh12
