Custom Recovery for Optimus V
Stock VM670 recovery img pulled from Optimus V
The recovery.img in my stock package was pulled straight from my Optimums V.
Sent from my VM670 using Tapatalk
Hi,
Where can I find a link or the file that takehull setup as the stock package
mentioned above?
I was using Rom Manager and accidentally updated to the clockworks custom recovery. I have looked everywhere for an original stock recovery image. So far, every Img I have found has resulted in a different looking recovery. The original had white lettering. The "stock" files I have found have blue lettering and an Android green background.
I didn't mean to update to a new recovery image and would like to just get the phone back to the "real stock recovery" for the Virgin Mobile VM670.
(Optimus V). Seems I may be only finding the stock from the Optimus S.
I know how to use the tools to put it on the SD card then I am using
the "AIO Rom Tool" and renaming the file to "vrecovery.img" After a
reboot, I still have the blue lettered and Android background recovery Image. With all of that said:
Where can I find a copy of the "Stock Recovery" that you mention where
you did a direct from the "Optimus V Stock?"
I see a download for a "custom recovery" and not the stock package you
mention. I wish to recover from my mistake and get the phone back to the Virgin Mobile V VM670 stock recovery rom.
I have searched many forums and tried several "stock" recovery images
and seem to be from the S model.
Would you be so kind as to let me know where you posted the stock
recovery you mention in this post. I want to make sure I am downloading
the right file for a change. It would be a huge help.
Thank you in advance.
Robert
i know I'm grave digging, but I'm in need of help when i put the third line in my terminal it says "cannot create /system/bin/flash_image: read only file system" i just rooted my phone and I'm scared to do anything without a recovery system to back up my rom.. Help would be greatly appreciated. and my stock one seems to not work when i boot into recovery mode it goes past the lg screen then stays blank
martin45
