Am i correct in thinking that none of this can be done from version ls670zvd? If so, can someone please help me? I would be really greatful. Thanks in advance.
Not really sure what you mean, but this can be installed from any firmware version, as long as you are rooted.
I rooted using gingerbreak, have gone through the steps several times, I get all the way through the steps and just keep getting the stock recovery. I'm baffled. Any help?
when it shows the $ this is where you type su
(check your phone also at this time, if your rooted *should have superuser installed already*, it may ask for permission, always allow) If it prompt says permission denied, then you dont have superuser installed or you are not rooted.
You want to extract the files (both) directly to your sd card (make sure sd card is mounted on the computer-drag finger down from the top part of your phone screen (notification bar), you will see where it says usb connected -select to copy files to/from your computer-select this then turn on usb storage)
Turn off usb storage after files are extracted to the sd card, otherwise you will get "no such file or directory" starting at cat /sdcard/flash_image > /system/bin/flash_image
Can this recovery be used in Optimus V or does it need to be ported?
Awesome! after spending a day reading the boards and loading everything I needed, I just flashed this and it took about two minutes. Thanks a million. Off to the Roms.
Titanium backup = yesShould I install Titanium backup and run that first and also, as stupid as it sounds, how do I get the files to the SD root. Can I take the SD card and put it into my computer or do I have to load the files from the pc to the phone. Thanks
I didn't get any errors while doing this, but my menu still doesn't give me an option to back-up and restore. I using c:\Android\adb shell to enter in the commands, should I be using a shell found on the sd card? Cause I tried looking for an adb shell to run on the sd card and there isn't one. So, I think I completed the step but I'm skeptical as to whether I did it right or not. And I don't want to try and flash a rom until I know for sure that it worked correctly, cause I don't want a paperweight. Thanks!
Sorry, but confused here. What menu are you referring to - the custom recovery menu? If you've booted into custom recovery and not seeing, for e.g., backup and restore, than your flash of custom recovery did not work.
Is it safe to use the cm cwm from Tom manager since all optimus's r the same except for the botton
