[Custom Recovery] Xionia Clockwork (CWMA v1.2518.6)
This is the log from Comand prompt. the phone did not restart and when i do power + Volume and home doesnt bring up anything about back up. just reboot, apply sdcard:update.zip, wipe data/factory reset, and wipe cache partition.
Did i do anything wrong?i have both of the files extracted on the root of the sd card and the phone is rooted
thanks
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Dan>cd c:\optimusrootzvd
c:\OptimusRootZVD>adb shell
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
$ # mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
$ # cat /sdcard/flash_image > /system/bin/flash_image
$ # chmod 755 /system/bin/flash_image
$ # mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
$ # mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
$ # flash_image recovery /sdcard/xionia_cwma_12518.6.img
$ # reboot recovery
# reboot recovery
c:\OptimusRootZVD>
You don't type the # sign. It should be at the beginning of each new prompt instead of the $ sign. Start over with adb shell, type su at the $ prompt. And look at the phone for permissions
You are not doing it right if u still don't have recovery. Are u unzipping the zip so its an ISO?
Sent from my PC36100 using Tapatalk
yeah i unzipped the files and i know im doin it rite because i run all the commands in terminal on my phone and when i get to the last step the reboot_recovery command it goes into the custom recovery fine. but once i leave that and turn my phone on and try to get back into the custom recovery its the normal lg recovery
Xionia 125186 shows message not supported on this phone. Unsuccesful. I'm using lg optimus s. My ohone is rooted with ginferbreak what can I do. I need recovery and nandroud backup and want to flash rom. Please help!
hello after i but in cat /sdcard/flash_image > /system/bin/flash_image i get canot create /system/bin/flash_image: ready-only file system same thing after the chmod 755 /system/bin/flash_image comand i get read-only file system
Make sure your extracting the zip to the root of your sd card.......should be 2 img. Files
Sent From My Super Awesome, Over The Top Optimus S.........Tapatalk......
Hey haven't u heard? Everybody knows that the bird is the word... Babababa the bird bird bird, the bird is the word........Thank You Jondevere......LOL......
You sure your rooted? You have superuser installed and is functioning.....
when you open the terminal emulator, make sure you type "su" to get your # prompt first. If not, you will be on the $ prompt.
whats the root of my sd i put in a blank sd card with both unzipped .images on it
taoujdate
