ToddShroats
Active member
- Jan 9, 2011
- 30
- 2
- 0
What is the flash_image? I am assuming the xionia_cwma_12518.4.img is the new custom recovery. What is the other?
Is there a reason you want to install the VC update from the OTA update.zip? Are you thinking that installing the VC update via LG Software Updater is the cause of your problem? I don't think that can be the cause by itself because many other people have installed VC via the LG Software Updater and they don't have this problem. If it is involved at all, there'd have to be some other factor.run the ##786# wipe, and then just run the OTA. I really don't want to have to re-play all those levels of Angry Birds since I won't be able to restore data from Titanium.I'm also unsure of that fixing the problem.
I know that if I have root, I can get Titanium. I was just side-tracking after getting some data for zefie. Mainly wanted to get his/others thoughts.Is there a reason you want to install the VC update from the OTA update.zip? Are you thinking that installing the VC update via LG Software Updater is the cause of your problem? I don't think that can be the cause by itself because many other people have installed VC via the LG Software Updater and they don't have this problem. If it is involved at all, there'd have to be some other factor.
If I've misread what you are trying to say, then if you install the VC update using the LG Software Updater (and had previously restored the V9 recovery image), you'll still be able to root, install Titanium, and restore what you had backed up in Titanium.
That's cool. I only asked because you mentioned V9 then installing OTA (VC) and I wasn't sure why you'd want to install VC that way unless you suspected something was off with installing VC using the LG Software Updater.I know that if I have root, I can get Titanium. I was just side-tracking after getting some data for zefie.
I also noticed that when going to wipe dalvik it came up with an error that a partition was missing /dev/block/mmcblk0p2. Does this have something to do with CyanogenMod or the /dalvik-cache to /cache mod?
I'm also seeing this when I try to do a Dalvik cache wipe. Any ideas what's causing this, or is it entirely normal actually?
I have CWMA Recovery on my Optimus V and I'm trying to access it but I'm not sure if I can as the phone appears to be in some form of a bricked state. I went to do the factory reset in the recovery menu and I had it plugged in via USB too. When it did the factory reset I though it would just shut down after that so when I saw it booting back up I thought it was because I had the USB cable plugged in. I pulled it and then the battery to kill it as I didn't want to wait for it to boot up and then just shut it down to get to the CWMA recovery menu. Apparently, you shouldn't remove the battery until it boots up fully to the home screen after a reset. I thought it already did the reset process completely and would be good to go.
Now I can't reach the recovery menu. When it starts up it always says it's doing a reset and then proceeds to reboot at which point it goes through the Virgin Mobile animation and gets stuck on the Virgin Mobile logo that remains behind during the boot sequence. It never even gets so far as the shimmering "android".
Any idea on how I can get to the recovery menu? Holding down the key-combo to launch it turns the phone on and it says it's resetting. Then it just freezes up again. Any help would be appreciated!!! O![]()
