custom splash screen
My modifications to the original
basically alot brighter with more lightning
Nice... I can't believe I found this thread just now. Hmmm .. which one to use. How do we get the old splash screen back on if I ever want to go back to stock? Will a factory reset take care of that?
You need the file a data wipe wont do it.
Not sure but an ruu zip, like if you're unrooting/going back to stock might revert it, but i dont really know for sure
I wonder if the Thread I started on how to "Create you OWN splash1 screen" in the incredible forums will work the same way for this phone.. both screens are the same resolution, im guessing if I just change the zip from PB31IMG to PB05IMG it would work for this phone too... I will try it out later.
You should make a new thread over here if you like. The pixel by pixel size is different as well. The same procedure should work (i cant see a reason why it wouldnt) except pg05img.
after you successfully flash this, is it safe to delete it from the root of the sd card--or does it have to stay there for the phone to access everytime on bootup?
(just rooted, still learning)
You should have put tattoo's and rings on that wallpaper, as well as tressels face after resigning
what exactly are splash screens? Boot screens?
the splash screen is the white HTC screen that first starts when you turn your phone on. then the "boot" screen is the one where the thunderbolt animation happens... they are two different things :) and you can change both of them if you want too... For the splash screen you just place on root of you sd card and the go into HBOOT and let the magic happen (follow direction when prompted)... to change you boot animation you need to find one you like but you flash it like any other zip in recovery
you can also delete them off of you SD card after installed if you want to. it wont hurt if you remove them
trusteeee
