CWM v3.0.0.6 problem
vlozano06
Active member
Dec 6, 2009
38
4
I'm trying to flash syndicate 1.1 in CWM and its getting hung at the samsung screen.
when i reenter cwm it say
E:can't mount /cache/recovery/command
E:can't mount /cache/recovery/log
E:can't mount /cache/recovery/last_log
i wipe data/factory reset 3x, cache 3x, and dalvik 3x, then install zip from sd. it goes through the process but it never boots completely.
also this is the only rom I have on my sd so, I can't try flashing another one.
any suggestions?
any suggestions?
Possibly a bad download... Could you pull your sdcard and put it into a computer to read it and place a new download on it?
Reactions: maxertx
I think it was just a bad download. I restored from an old backup I had. Then redownloaded it, and it flashed with no problem. thanks for the help.
Jokerman
