CyanogenMod 6.1 RC1 is out now
Another feature I'm liking is the condensed widget menu. Instead of listing all the widget styles available for one widget, they're condensed into one.
That's been around the nightlys for a while, I love it though. That list can get messy after a while.
I also like how you can disable 270 degree rotation.
Is anyone having issues with the market not downloading? Keeps telling me the downloads are unsuccessful
Tried that with no luck...I've seen a couple posts from Droid owners about the market possibly being down dunno if that's the case or not
I'm having the same issue. Since I had just flashed 6.1 I thought it was the rom. Guess I will give it some time to see if it comes back up.
Can I ask why is my signal always so low with this rom when the first time I tried it when the first nightlys came out. I had to switch cuz of this I thought it would be fixes but same problem.. is these some type of special radio to be flashed
CM6 shows Data signal and not Voice signal. Download real signal from the market and you will see what your voice signal is. There has NEVER been a signal issue with CM6.
The number of bars means nothing. CM uses less bars than Sense, CM has 4 bars and Stock has 5 (I think.) As long as you are getting good speed and aren't having connection issues the bars don't matter.
Im dieing to try this rom! i just fired it up after rooting my new evo! the forums add ons for the market and such are currently down at the moment and i cant find these addons elsewhere..
anyone have a link?
EDIT: nvm lol i found it on my SD card
Usually a clear cache AND a reboot fixes that right up. Also if you just restored some apps and then go right to market I notice it doesn't always work so great.
That would be awesome!
Say, I'm getting some screen tearing..anybody else noticing that?
Yes, when sliding home screens side to side. I first saw this with the snap kernels on the older CM6 releases when they still worked together.
It's probably how it's getting around the 30 fps cap.
Battery
I'm loving the new CM. I haven't used CM in a while and I'm curious what the best way to setup good battery performance. Should I be using a different kernel? Anyone had any luck playing with different kernels in CM? Should I go with setcpu settings or is CM already pretty well optimized for battery life. Please advise.
Use set cpu on everything haha.
I like snap turbo or just the stock cm kernel. Cyanogen is on the verge of releasing a new kernel .35, along with hdmi.
Does this update still have the annoying text message when you receive a voicemail? I also had EAS email issues where Push would stop working. Works fine on MYN's.
mylesgray9696
