Cyanogen's Nightly Builds
Anyone know what was changed in last night's... nightly?!?! I noticed that I can't sync my facebook with last night's copy of CM6... I'm new to all of this and with that go ahead and treat me like a noob :) I'm lovin root and CM6 is just perfect (mostly) as far as the scrollable people widget, I purchased launcher pro plus.... I prefer it to ADW Launcher... it's a $3 donation and completely worth it... must be bought outside of the market since the dev lives in an area not supported by the market place yet (pfft)
go here if your interested -> Introducing the new LauncherPro Plus!
I'm checking it out now! Haven't noticed too many changes yet but we'll see. I'm still unable to get Handcent in the market and Facebook is not syncing for me!
You wont see any protected apps right now. I'm sure our friends over at XDA have the apk for you ;-)
Sent from my HTC EVO using Tapatalk
Define "protected apps"... I can't see Fring or Google Voice!
Why are these protected and what, exactly, does that mean?
Thanks!
Go here for the handcent apk and for others too ;-)
http://forum.xda-developers.com/showthread.php?t=731637
Thanks!
It has to do with the dev. Its a protection so his app doesn't get shared or something like that I was told. Don't worry about fring. Its not working with this build.
Where are Said Scrollable Widgets?! **Look at me asking questions again**
I wanted the People scrollable widget dont care so much about a Calender
Ah... That I do not know. What I meant was that ADW Launcher allows widgets to scroll. In the Pure Calendar widget, there's an option for allowing scrolling in either ADW or Pro. I assume there are other widgets out there that take advantage of this functionality, but I don't know what they are.
Android Agenda scrolls. It's GREAT! And the built in replacement to the 'People' widget provided by LancherPro+ is excellent, too.
Surprisingly i got both to work. I wiped everything prior to install, and only restored apps and ADW settings. Fully function 2.2. Will report back on the Nightly shortly.
If your mms is not working. Completely wipe cache and dalivk and system. Then flash. MMS should be good now as well as the battery drain issue. Will report back later.
im on the road tethered to my phone ha so ill DL the newest build and just overflash it and see if mms send is up...
soraplzzzzz
