Cyanogen's Nightly Builds
new nightly
I flashed the 7/28 rom with rom manager and it seems like I can't download nothing in my phone. Not with the market or trough 4shared. If anyone knows of a fix let me know.
Do you get a force close?
Does it just not open the download?
Have you checked browser--> menu--> more--> downloads?
Also, I would check (lastly) out the actual thread on XDA and report it there.
yea im wiping completely, still not sure if dalvik's cache is getting wiped because there is no confirmation in the latest clockwork recovery.
Yeah this recently started happening with me too. I might use Rom Manager to get Amon... though I've never used that recovery before.
found 2 issues with yesterdays build... I like to use the Polic Scanner application when there are tonado warnings out but last night when I went to use the Police Scanner app it would only play out of the ear piece, no speaker. I never had any issues on 2.1 so not sure if the app needs to be updated or something needs to be fixed in the ROM.
Also, I noticed that my screen will dim but will not shut off. I normally use the power button to shut off the screen so it's not a real big deal but this should be fixed...
Otherwise really enjoying the CM6 on EVO...
The issue I had last night got fixed I could download apps from the market and I didn't do anything to fix it but it works now. The only thing is that I can't back up my apps from my back up pro. 7/26 update I was able too.
Downloaded last night's build and both issues are resolved. Not sure if it was the build or the phone just needed to be rebooted. Now my only complaint is that the vanilla contacts app will not access the Exchange GAL. Can access it via email but not contacts. NOt a huge deal but we populate our GAL with phone #s. The Sense contacts app DID access the GAL. Anyway to just install the Sense contacts app without everything else?
I downloaded Adobe Flash Beta from market...
... but I couldn't find a way to disable it through the browser settings, so I just uninstalled for the time being.
QuriousOne
