D2 full of bugs...
i tired this with my wall charger and I did not see anything out of the ordinary< I just tried my dock and still not an issue. I do have a case.
it only happened to me once and it was in my car dock, I will say that the power cord I ran for my car dock was alittle rigged for now. other than that its been good, no other problems. I switched from a blackberry after 5 years I think I made the switch for good!
anyone having the issue when the phone is locked on the home screen it will say a weird message with a bell next to it? For example:
"this phone belongs to John Smith. If found please contact 654-232-5553"
The names and messaging have been changing every few hours. I have NO IDEA who these people are or what these messages are. Have I been hacked?
Heard of some other people with this problem.
You've installed a malicious antivirus program. Specifically, Antivirus free or Antivirus Pro. After you remove it you may also need to remove a secondary app called CoolDown.
You do not need antivirus on an Android phone.
I used my car dock the whole way to work and I did not have one problem. Maybe it was jsut a bad connection to micro usb port the time it happened. Still problem free other than that one issue
I was having that problem as well. I thought it was associated with my anti-virus program though.
I actually called Verizon to ask if it was possible that I was given a phone that had previously been opened, used and then returned to the store prior to my purchasing it.
I even went so far as to do a factory reset.
No wifi issue here. I can keep a strong signal no problem on my D2. Sync, and Facebook issues that you mention i can't recall either :(
I can second that haptic feedback issue.It drove me nuts for the first couple of days. Getting used to it, but would like an option to turn it off.
Getting a weird double-click-y lock sound when i put it on the dock.
I do have some signal weirdness too - sitting in the same spot i can get 1-bar to 3 bars then back down to 2 bars. When i am on a call however it seems to go to full-signal. Anyone else having these reception oddities?
When I went to the verizon store yesterday, I asked if there had been any complaints and the rep said he hadn't heard anything yet but that motorola will be sending out a patch soon for some other 'bugs'.
LOL, for some reason, I never believe the sales reps when they tell me they haven't heard of varying problems on these phones.
scoobyd031883
