Damaged Micro USB Cable: Do I Need to Buy Samsung Cable for Fast Charging?
enduro
Active member
Apr 8, 2011
44
Hi all.
I've had my S6 Edge for just under 12 months now and over last few months have noticed odd things happening with charging which include the phone actually discharging while on charge. I suspect it is my OEM (Original Equip. Manufacturer) charge cable as on inspection the wire on the micro USB end has slightly browned. When I charge my S6 Edge using my Galaxy Tab 2 I have no such charging issues but it does charge slowly.
A while back, I accidentally mixed up the micro USB cables, but not the chargers and was charging my Tab with the S6 cable and I recall a "charging slowly - plug in your original charger" message coming up at time. This might indicate that the S6 needs a proprietary cable for charging.
So the primary question: to use fast charging, do I need to use the Samsung proprietary cable to access fast charging? I now need a replacement.
Nope, but you will need a high quality cable. A low quality cable can't handle quick charging. Doesnt have to be an OEM cable but just a high quality/standard cable will be enough.
Posted with ❤Love❤
Hi all.
Answer : no.
Fast charging is done via the adopter usb cable have no role in it. Any cable u got will do the job as long as your adopter works.
If the charge current - which is fixed, and set by the design of the phone - is smaller than the amount of current the phone is using (which is rare), the battery will continue to dischare even though it's on the charger. (Charge current = current coming into the phone - current being used by the phone.)
That sounds like a problem in the S6, not in the cable. Brown usually means that too much current for that size wire was flowing in the wire.
Sort of. Samsung plays with the extra pins on th microUSB connector to tell the phone different things - like USB/AC charge, or fast/normal charge.
As everyone says, there are probably good replacements - but not a $5 cable. And a good replacement might cost almost as much as an original Samsung.
After market a good quality cable is just as good, if not better
My troubleshooting with 7 different cables showed me that the the very new Samsung charger cables that came with non-fast-charging phones did not fast charge when connected to the fast charger adapter portion while. It appears that the cable does in fact matter. I tried many combinations of cables and adapters during my testing.
rlawernce
