Dark themes
I like the oreo_black theme. Where did you get it if you don't mind me asking?
Also the weather app, is that a stock weather app ?
Notifications are black even. I'm patiently waiting. Tried to install substratum the day I got the phone with no luck. I am currently using Black_Edition_V2 as well and like it. Also using navbar to make my navbar black.
Swift black and dark work, it just doesn't theme the Samsung messages.
What I did was build and enable. Then restart my phone, go over to manager and select them all and applied them.
Found "High Contrast" theme that I loved on my S8 made by Samsung, but the creator is now called "theme.seller".
The advantage of using the Samsung created one is that it correctly changes text bubbles in the default messages app which is screwed up when you use a third party dark theme... :(
It's in the theme store... Just long press a blank spot on the home screen and click themes...
Yes that's a stock weather widget
I installed Black Edition V2 on my Verizon 9+, but Google Play still has white background. The general UI is black, but GP, Maps and other Google apps are still white.
I have a Samsung theme installed (the one I mentioned above) and I got the overlays to work on top with substratum. I could not get messages to take the substratum overlay and plus I can use a custom accent combined with my favorite theme.
Yeah, you have to use substratum to get everything else black. I use both black edition v2 and also use substratum swift black. The combo blacks out pretty much everything.
I've been using Black Luxury for a long time. I try other themes, but always come back to this.
Using "Material Black"...just a plain old Samsung theme. I really like the minimalist look. Does cost a buck, but worth it to me *smile*.
rosannejoy555
