Data Connection Not Working on Nexus 4
AlexanderJJJ
12
Just received a white unlocked Nexus 4 8GB in the mail and while I've been joying pretty much everything about it, it seems when I try to turn on my data connection nothing happens. On the signal bar it's still grey and no type of data signal shows. When I load up a webpage nothing happens too. I'm using a US unlocked version on AT&T. Anyone know a way to fix this?
Does it turn on? You may have to set up data APN for you provider
- - - Updated - - -
You need to set up the proper apn on your device. It's not a big deal I'm an AT&t customer and had to do the same. Search the forum for inductions.
Sent from my Nexus 4 using Tapatalk 4 Beta
My father has a Galaxy Nexus that he's also using on AT&T and checked the APN settings were exactly the same as my Nexus 4, so I don't think APN is the problem..
Sorry, but covering all bases before answering. Did you purchase an 4/4G data plan with your SIM card? Use the APN that has mobile.att.net in its settings. And delete the default APN - you call always get it back later.
Sent from my Nexus 10 using Tapatalk 4 Beta
aimalee
