ARCHIVED: [DEAD ROM] nROM v1.6.3
Status
Not open for further replies.
Hey guys, I've been having issues with my touchscreen. With it sitting there and me not touching it apps will open, and screens will change. Anyone else having this happen? I'm trying to figure out if its a ROM issue or a rogue app issue.
This may sound crazy
But I am so glad other people are having this issue,
when I first started bringing up that my screen had the jitters
and that icons would pop up on their own I had people tell
me they never saw that before, and then go on to say that maybe I had
warez apps on my phone that were causing it.
So I was glad to hear that LG had updated the LCD drivers in VC because of the problem,
but it seems that its not 100%, I still get screen issues most of them are now are in the browser.
The best luck I had was running Thunderom 1.5, but installing it after the VC update gave me the OTA error, and no 3g data.
We have 3 Optimus S phones in the house, and only mine does it,
yes I'm the guy that gets to find the hair in his meal every time too!
what I have noticed is a color difference in my screen from my wifes and sons
they have a slight yellow tinge, my screen seems brighter at the same brightness setting, whites are brighter on mine.
is there anyway of knowing if my screen make is different than theirs ??
is there a way of turning down screen sensitivity ??
So, yesterday, I installed Nrom 1.5.1...
Today I discovered that I wouldn't get any response if I tried to update the profile or PRL...
Is anyone else having this issue? (or am I just *special*)
Just push a new Mvpdm.apk from a nandroid backup. You will first need to unpack your system.img and grab the system/app folder, or just Mvpdm.apk.
Can we expect a new ROM sometime soon that will take care of everything that's not going right? I really like the ROM and want to stick with it.
What problems are you having? Just the PRL / profile updating? That's an easy fix. I'll release a patch after class.
Nick7 : Tremendous update; it feels like I'm running a new device-- THANK YOU!
Quick question/Potential bug: When I open the app drawer, only some of my applications are listed. I verified the apps are on the device however they aren't appearing in the drawer.
Thanks, in advance, for your feedback.
PS: Are you as excited as I am for Thursday's 60 degree weather?
Hmm sounds like a LauncherPro bug. Try pressing menu -> preferences -> restart LauncherPro. If that doesn't work try to see if any apps are hidden : menu -> preferences -> general settings > hidden apps. Let me know if that helps.
And heck yeah even this 30 degree weather tonight feels nice! Last week was brutally cold.
Thanks Nick 7. I rebooted and all the applications magically re-appeared.
Again, thanks for all your hard work and countless hours you've spent developing and customizing this awesome ROM.
Hey no problem!
Yeah I realized why I removed mvpdm.apk in the first place. It makes the phone act all crazy. So for now if you need to update your PRL or profile you need to revert to v1.4.5, update, then reflash v1.5.1. I'm still working on a fix but this is a work around. So let's recap:
  1. Flash v1.4.5 - Don't wipe
  2. Update PRL and profile
  3. Flash v1.5.1 - Don't wipe
Boom, like nothing happened and all updated. Still looking for answers to this..
Random question: Using ES File Explorer, is it ok to rename specific folders on the SDCard? (For example, can I change the folder currently named com.google.android.apps.listen to Google Listen?) Thanks for your help.
Hmm that sounds like a cache folder. I have a feeling that if you do rename it google listen will just build another folder named com.google.android.apps.listen.
Wow you removed voicemail! I'm flashing 1.5.1 just for that. I hate voicemail and hate that you cant clear notifications without playing the voicemail.
Thanks Brudda!
Thanks Brudda!
Lol well you are very welcome. Enjoy your voicemail-less phone!
Well I have been running the nrom on my optimus for about a week and it seems work well. Haven't had any problems, I upgrade to vc using the lg install from my computer and then went about rooting. I tried nrom first because it stated that I wouldn't loose my existing app's.
I'm glad it's working out for you :)
I cannot use the WIFI tether anymore. Phone says tethering is currently running but my laptop cannot see it. Help.
Status
Andacar
