[DEAD THEMES] Optimus s Froyo -=Theme_Team=-
Re: [THEME] Reborn-Shell ROM Theme Kitchen --Theme_Team (NEW 7/3
Don't wanna be a bother but can you make simple G for shell rom
****UPDATE****
Theme simpleG is now available for Shell ROM. See Downloads section of post #3.
****UPDATE****
Digging the new system font bigtime. Props for sure. You will make a happy man if you can make the clock in the corner go away.
Well your gonna be one "happy man". LOL enjoy!!!
no_clock-shell-mod.zip
This flashable zip does not contain any theme. It is to be flashed at any time to remove the clock only. You can simply reflash any theme or the ROM itself to get the clock back.
Post #3 will also list this file for download.
Credit goes to SteelH over at XDA for the mod instructions.
It's the thought that counts. Seriously.
I agree I know if I had alot of time in my hand and had internet at the housr I would push my self for theming I apreciate evrybody work for the optimus s this phone has potentual they should really have a rom called optimus prime s just cuz of optimus thats y I like the phone if not I would of had a nexus by now
Bravo bro. Looking good homie! Loving all the options.
Really like the noclock mod for sure. I use minimalistic text widgets to show the time & less on the screen is awesome. One fix I might request for simpleG is any application I'm in and hit menu and the more option shows a tinted black menu with black text. Every other menu is white. Not sure if this is the case for reborn, but it is on the Shell version.
I'll take a look at that, good find.
just flash the Orange Transparent...but it is stuck on android boot screen. anyone else have this problem?
Which Rom are you using? That theme is only available for reborn right now.
yes reborn 2.2.2. Although i did something... before i install the theme, i did a wipe of data,cache and dalvick...would that have cause the error?
nvrmind...that is the problem..but now the background is the blue background from the rebornrom with orange bars...hmmm...weird.
Ok, ya you can't wipe data. Cache and dalvik is fine but not data. Restore your nand or reflash reborn, let it boot all the way and then reflash the theme.
Reactions: clrstren
Ya the themes do not change your background. You have to long press on your homescreen to do that.
........ One fix I might request for simpleG is any application I'm in and hit menu and the more option shows a tinted black menu with black text. Every other menu is white. Not sure if this is the case for reborn, but it is on the Shell version.
***UPDATE***
This issue has been fixed in all three themes i released so far for Shell ROM. (reTouched, simpleG, and blueTouch)
OP and Post #3 updated with v1.1 of each.
Reactions: fatal99
Re: [THEME] Reborn-Shell ROM Theme Kitchen --Theme_Team (NEW 7/5
Hey I was wondering if you could make a theme where you use the stock icons with your reborn theme because well i don't like the icons that come with your theme and also if you could emulate the power control widgets style in to your status bar drop down control center.
Ok, first off, are you talking about my theme called "reTouched"? And you want the regular LG Optimus s stock icons, battery and all? As far as the power control widget area, I'm not sure exactly what you want done there. What do you mean by "emulate"?
Can you make a no clock mod for Reborn? I am using the reTouched theme. Or will the Shell ROM one work?
No the Shell one won't work. I have been meaning to make it for Reborn, but just been getting sidetracked. LOL. Let me see if I can do it real fast.
Reactions: kpfeiffer
Here is reborn's no-clock mod. I did NOT test this, so please make a nand first but it should be fine.
no_clock-reborn-mod.zip
I will post it in post #3 once I know it works. Sorry it took so long.
Bry
