[DEAD THEMES] Optimus s Froyo -=Theme_Team=-
Yes sorry, as jon stated it's part of the reborn rom itself .
But I do have a question, are you saying that you're using the themes that we've made here with thunderom?
Sent by Tapatalk ----- Optimus s
It's technically POSSIBLE to get the notification power control bar on ThundeROM, but then it wouldn't be ThundeROM any more.
It's also possible to use Reborn themes with any other ROM, but it may look strange at some points and won't have the power control bar.
In my opinion you only need the Blue Torch V2 Plus Dock. I doubt there is much demand for the previous versions but correct me if i'm wrong :)
Depends on what u like. V1 has the stock power notification icons. V2 has different... so both are in demand. Thanks for the input tho! Glad u like the theme
Well, maybe someone wants it with the original notification icons, maybe someone wants it with the stock dock, maybe it doesn't hurt anything leaving those options available, so maybe you are wrong. :)
Its Purple Durple Time ! ! !
Check out Post #2 to get your download of this theme
i was using Reborn, had battery drain issues big time, so I switched to ThunderRom, and yes I'm using the green swype, and the blue contact dialers, I tried one theme and my phone didn't reboot, so I removed it. Thanks though, I'm happy with what I have, don't need any themes or the dock.
On the notification power controls, are they supposed to be grey (as shown) or teal? My bars light up teal instead of grey which is shown in the screen shot. Just curious.
You need to go into your apps drawer and go to Power Control Widgets Configuration. You can change the color for the tabs there. Its called " Indicator color ". This is what we do with all of our themes to match how we like it.
Reactions: cfallsguy
Oh cool. Never even paid attention to that until now, thanks. Appreciate all the hard work and how quickly you guys put out new themes.
I would get reborn rom but one thing I dont like is that EU instead of 3g..if that was change I would defenately get reborn rom those them are great but that bothers me alot........it would be cool to feel special ....just joking
You dont like that it shows an image for EV instead of 3G? You know there is no difference in the actual speed.. Its just an icon change.
Crusher
