Dedicated Screenshot Button?
Np:) yes I love it. It is definitely easier. I still have mine at the bottom. Only because it's a habit to go down there lol. Its like one time I'll use the edge one then I catch myself using the ones at bottom lol. I kind of like having both options available at same time. But I see why you wouldn't:D
But the cool thing about hiding the bottom soft keys is all you have to do to see them is a quick slide up from the bottom, which I didn't discover until playing after hiding it.
I'm six weeks weeks in on my N8 and still learning new things. I love this!!
I'm going on 8 weeks and still learning and loving this bad boy. Lol. Oh you talking about that. Lol. Yeah I have it set already to where I can slide bottom ones up. For some reason I was thinking you meant you were able to get rid of it somehow. Had to read it again haha. But yeah plus you get a little extra room when you can hide the bottom keys.
I just use the palm swipe since I'm holding the phone anyway. Unless I want to write something on it then I use the pen.
In the task edge panel, there is already a "take screenshots" button. You don't have to download the soft key panel if that's the only button on it that you think you will ever use.
In the task edge panel, there is already a take screen shot button. You don't have to download the soft key panel if that's the only button on it that you will ever use.
Where?
Edit: I found it. Thanks.
I find that the SPen and the screen write option to be the best. I often want to annotate the screen shot after I take it so this combination works out perfectly.
If you can't find something like Edge panel etc., ask Bixby. It works like a charm to find things.
DonJrPlayz1234
