Delete or uninstall themes!!! HELP!!!
hannahe26
16
i can not for the life of me figure out how to uninstall or whatever it is you do for themes i got it and have no idea how to take it off. i went from an iphone to the galaxy s4 and im still trying to figure out the basics. let me tell you its very difficult. :eek::eek::eek::eek::eek:
Try settings, then more, then application manager, then make sure you are looking at downloaded apps, then click on the relevant app and you should be given the option to uninstall.
Did that work?
Did that work?
no there arent any downloaded apps that have to do with the themes... do you know of the Go SMS Pro keyboard app ? i downloaded that and i think the theme may be coming from there but i dont know what to do...
Is it the go sms keyboard you installed and want to remove? If so then click your menu key and click on settings. Then go into your application manager and delete the go keyboard and it will take the keyboard and theme for that keyboard away. Are you wanting a different keyboard?
Sent from my SAMSUNG-SGH-I337 using Android Central Forums
Worked like a charm...settings>applications>applications manager - choose app and choose uninstall. I'll not put back that "Go Keyboard" again.
Hello !!
I bought a huawei and it comes with pre-installed themes from the mobile operator.
I ask the code for make the phone free for all operators and I already root my phone. However I can't get ride of that stupid them. Could you help me??
Anything more up to date than 2013 please. I h ave a galaxy S7 edge and
Although the app would appear to have installed how do I uninstall It.
Similar problem. Very anoying...
How do I uninstall Samsung Infinity wallpaper on S8?
Somehow, I set the Samsung Infinity wallpaper on my S8 (not sure how).
Problem is I cannot take it off my lock-screen and home-screen because:
- there is no Delete option in Samsung Themes, only apply
- each time I apply a new wallpaper (from Samsung Themes or another wallpaper app), I see it once and then it gets automatically replaced (both in the home and lock screens) by the Samsung Infinity wallpaper as soon as I unlock the phone
- I can't uninstall Samsung Themes
In other words, Samsung Infinity wallpaper has taken over my home and lock screens.
Help !
jackgomes0321
