Differences Between American Models of Nexus 5 and Nexus 5X
ptonantryloc
183
As near as I can tell, the following table lists the DIFFERENCES between the American Models of the 2013 Nexus 5 and the 2015 Nexus 5X. The data comes from:
LG Nexus 5X vs. LG Nexus 5 - GSMArena.com
[table="width: 500"]
[tr][td]Feature[/td][td]Nexus 5 (2013)[/td][td]Nexus 5X (20150)[/td][/tr]
[tr][td]3G Network[/td][td]HSDPA 800[/td][td][/td][/tr]
[tr][td]4G Network[/td][td]LTE band 19(800), 41(2500)[/td][td]LTE band 3(1800), 7(2600), 12(700), 13(700), 20(800), 29(700)[/td][/tr]
[tr][td]Speed[/td][td]LTE Cat4 150/50[/td][td]LTE Cat6 300/50[/td][/tr]
[tr][td]GPRS[/td][td]Class 12[/td][td]Yes[/td][/tr]
[tr][td]EDGE[/td][td]Class 12[/td][td]Yes[/td][/tr]
[tr][td]Body Dimensions[/td][td]5.43 x 2.72 x 0.34 in[/td][td]5.79 x 2.86 x 0.31 in[/td][/tr]
[tr][td]Weight[/td][td]4.59 oz[/td][td]4.80 oz[/td][/tr]
[tr][td]SIM[/td][td]Micro-SIM[/td][td]Nano-SIM[/td][/tr]
[tr][td]Body Other[/td][td][/td][td]Fingerprint Sensor[/td][/tr]
[tr][td]Display Type[/td][td]True HD IPS+ capacitive touchscreen[/td][td]Capacitive touchscreen[/td][/tr]
[tr][td]Display Size[/td][td]4.95 in (70.8% screen-to-body ratio)[/td][td]5.2 in (69.8 % screen-to-body ratio)[/td][/tr]
[tr][td]Display Resolution[/td][td]1080 x 1920 (445 ppi)[/td][td]1080 x 1920 pixels (424 ppi)[/td][/tr]
[tr][td]Display Protection[/td][td]Corning Gorilla Glass 3[/td][td]Corning Gorilla Glass 3, oleophobic coating[/td][/tr]
[tr][td]Chipset[/td][td]Qualcomm MSM8974 Snapdragon 800[/td][td]Qualcomm MSM8992 Snapdragon 808[/td][/tr]
[tr][td]CPU[/td][td]Quad-core 2.3 GHz Krait 400[/td][td]Quad-core 1.44 GHz Cortex-A53 & dual-core 1.82 GHz Cortex-A57[/td][/tr]
[tr][td]GPU[/td][td]Adreno 330[/td][td]Adreno 418[/td][/tr]
[tr][td]Camera Primary[/td][td]8 MP, 3264 x 2448 pixels, autofocus, optical image stabilization, LED flash[/td][td]12 MP, 4608 x 2592 pixels, laser autofocus, dual-LED (dual tone) flash[/td][/tr]
[tr][td]Camera Features[/td][td][/td][td]1.55µm pixel size[/td][/tr]
[tr][td]Camera Video[/td][td]1080p@30fps, optical stabilization[/td][td]2160p@30fps[/td][/tr]
[tr][td]Camera Secondary[/td][td]1.3 MP[/td][td]5 MP[/td][/tr]
[tr][td]Bluetooth[/td][td]V4.0[/td][td]V4.2[/td][/tr]
[tr][td]USB[/td][td]microUSB v2.0 (SlimPort), USB Host[/td][td]Type-C 1.0 reversible connector[/td][/tr]
[tr][td]Features[/td][td]Wireless Charging (Qi-enabled), Voice memo/dial/commands[/td][td][/td][/tr]
[tr][td]Battery[/td][td]Non-removable Li-Po 2300 mAh battery[/td][td]Non-removable Li-Po 2700 mAh battery[/td][/tr]
[tr][td]Colors[/td][td]Black, White, Red[/td][td]Black, White, Blue[/td][/tr]
[/table]
mkmobilearena
