discharges on wireless charger?
kaufmansm
174
When my phone is on the vzw wireless charging stand it lights up, phone says it is wireless charging and aprox charge time. but the phone discharges. Any ideas?
how do i do that? and what else will that wipe out?
It won't hurt anything.
Turn the device off.
Hold volume up rocker+home button+ power button at the same time.
In manual mode, use the volume rocker to toggle to clear cache partition. Power button to accept.
Then, use the volume rocker to reboot. Power button to accept.
Only lasted one time. A reclear of cashe did nothing
If you don't mind having to set your device again, try a factory reset. Settings/Personal/Backup and Reset. If it persists, it might time, depending upon how long it's been since your purchase, to consider your exchange your device. As long as your device is aligned properly, it shouldn't discharge while charging.
Still no good. Went and exchanged the charger, still same issue. I'll give it another try after the next update.
edaeeadae
