Forgive me if this has been covered before. I searched extensively but wasn't able to find an answer.
The problem started suddenly about a week ago. I didn't download any new apps or use my phone any differently, it just began out of the blue...
If I charge my phone to 100%, unplug it and set it down on the counter, it will be dead within 4 hours. GPS, WiFi, BT and 4G all turned off, with very good 3G signal. When I look at my battery usage it shows the Display as using +90% of the battery charge, even if I never once turn the display on. It drains so fast my USB laptop charger barely keeps up with the drain, charging the phone takes 10 hours using it! The wall charger and car charger are faster but still... effing ridiculous.
Honestly I don't know the first thing about these phones, I've never rooted or ROMd one before. It's 100% out-of-the-box stock aside from apps and I'm a light user (about 500MB/mo) Here's some info that might be helpful:
Android 2.3.5
Baseband 2.15.00.12.19
Kernel 2.6.35.10
Software 5.07.651.1 710ORD
PTI 2.33_003
Where do I begin? I can't find any (obviously) offending apps or tasks that would be eating up milliamps like this. But my Up Time and Awake Time are nearly identical and it's really effing hot, which leads me to believe the phone is cranking away at 100% all of the time, for some reason.
Any ideas?
Android 2.3.5
Kernel 2.6.35.10
PTI 2.33_003
Any ideas?
