dlo9 root questions
Try method 3
Sent from my SCH-I500 using Tapatalk
ive done method 3, it says it works, but on reboot its not rooted.
i think it thinks its still rooted an causing errors, so i wanted to remove all trace of root. how do i uninstall superuser?
finally got it, i ran rageagainst the cage, fot the # prompt
then did this, found it someplace i acnt recall
su
mount -t rfs -o remount,rw /dev/block/stl9 /system
rm /sdcard/Superuser.apk
rm system/xbin/busybox
rm /system/xbin/su
rm system/bin/busybox
rm /system/bin/su
rm /sdcard/su
rm /sdcard/busybox
mount -t rfs -o remount,ro /dev/block/stl9 /system
exit (first "exit" takes you out of su)
exit (second "exit" takes you out of the terminal)
reboot
then rerooted, and seems to be working now
Nammna
