- Apr 23, 2011
- 30,108
- 207
- 63
Where and how can we buy the jbutterfly? I'm gonna assume that the phone will work on Verizon's network?
Sent from my HTC Resound using Tapatalk 2
Maybe. The j butterfly is cdma and gsm so in theory, the radio would work. The radio firmware may have to be modified. Verizon cdma only phones will work in Japan to a limited extent, so it should work the other way as well.
Additionally, verizon would only allow phones on their network of their choosing (esn in their database), so you would also need a donor phone, and esn cloning is a gray area at best.
If you absolutely must have the j butterfly, buy it and get it activated to a Japanese carrier with usa roaming capabilities. Then use it in the USA roaming on Verizon's network. Keep in mind though that roaming is typically extremely expensive. But if you must have it at any cost... Then it is possible.
Sent from my Verizon Galaxy SIII
