Do I need Battery Doctor or Clean Master?
Those apps are generally garbage. I've never cleaned an Android phone, never used a task killer or battery thing. The One has a sleep option in Power settings that shuts of the data search when it's sitting around. I leave that one.
I have the Sleep mode on as well. I deleted battery doctor and noticied battery improve big time!
Clean Master, unsure of? Whether it works or not, I do not know?
I come from iPhone and most recently Windows, was concerned about viruses, etc... If I do not have to clean anything and just go about my biz, that works for me.
After using battery doc off and on for a few weeks I've noticed a power savings and better battery life after deleting it off my ONE. Kinda weird since its supposed to improve battery life.
Did you delete Clean master too? I'm new to Android and never used these types of programs with either iPhone or Windows.
Ditch it. I remember when I got my first Android phone (the HTC Incredible, great phone) 4 years ago the guy insisited I needed the Task Killer app. NOT!
Thanks. I did hear you don't need all that junk as Android is suppose to work on its own. with that said, I downloaded File Manager. I have no idea why and see no use for it unless I am missing to learn about it? Looks like my file folders on my PC ?
I am using both right now, but do not if I need them both? Advice?
You don't necessarily need either, but it's nice to have both. Battery Doctor itself doesn't prolong battery life, it has it to where you can setup personal settings, like turn off wifi, and data. Battery doctor helps your mobile device recharge more efficiently, my tablet was taking way too long to recharge so I used this App, and the recharge rate was increased significantly. That's really the only reason to have Battery Doctor, for the 50% faster charge.. Now Cleanmaster is very nice, it is the best App Killer/Task Manager App out there that I could find. Androids App Killer does not do nearly as much as Cleanmaster, nor does it go as deep into your system like Cleanmaster. Get rid of Battery Doctor, unless you want a faster recharge. Keep Cleanmaster, you want it to clean Junk Files mainly your Cache, and Risdiual Files. Also, using this to uninstall is best, when you uninstall Apps it leaves "risdiual files" behind, those can reach any size, even had one junk file that was 250mb, that's a big file for residuals. I've been using Cleanmaster around 4 weeks now, and I've cleaned over 6gb of junk files already. Even Battery Doctor leaves risdual files. Cleanmaster's App Booster is better than App Kill and Battery Doctor. Stopping power draining Apps, and boasting ram. Having open ram is always wise. Cleanmaster has everything Battery Doctor has, except for recharge booster. Keep Cleanmaster, I also have CM Security App, which goes right along with Cleanmaster. It's a very good anti-virus program for your mobile device. Keep Cleanmaster...
Thank You. After installing CM, I get an option to lock Facebook, messages and Twitter? It says I can lock down due to privacy issues?
It's true. I quit using them after trying some for nothing. All they do is waste resources and battery.
I want to know that why there are two battery apps of the same company. Like cm battery and battery doctor.
Can anyone tell me why their are 2 battery apps of the same company. Like battery doctor and cm battery. And which is better
Please read the posts in this thread, No one who posted is using them or apps like them. In the comments you will see that you are better off without them.
How to deactivated find phone feature or delete/edit the number on clean master security?
Why do I need to give my contact information for the Lock mode?
When your device is locked, you can choose to display your phone number and email address on the device. This means that if you lose your phone, the kind stranger that finds it will easily be able to contact you to return it.
I have used that feature on clean master security but now I uninstalled it because I want to edit it but I have no idea how to delete or edit my contact information?
Thanks for your help...
Regards...
I had clean master and liked the way it cleaned things up, but it slowed the phone down - and then I noticed alarms I was setting weren't going off and the clock wasn't working properly. Uninstalled it and problems solved.
ajay550
