Do live wall papers take a lot of battery?
Jon Jackson
800
Just curious, seems like they did in the past, wondered if they were still considered battery killers.
Yeah they still use more than a standard one.
Sent from my T-Mobile Note 3 using AC Forums.
Thought so....,yesterday in 12 hours my phone used only 15% and today in 5 hours its used 15%
It is mainly due the processor constantly having to run the wallpaper versus just showing a static image which is basically nothing for the processor. I use the pure black one from AC (Pure Black Wallpaper | Android Central) on my phone.
I've heard about using black. My live wallpaper is so beautiful though lol.....6 hours and I am down to 77% though....going to use it for a few days then switch back to something static and try to gauge the loss.
I think it still depends on which one you're using. I use Muzei with the dropzei plugin (for Dropbox photos) and it updates every hour. I don't notice much difference between that and a static wp.
Are you talking about a widget?
Is the usage the same from day to day? And even if it does use more battery, does it affect how you use your device? If not, enjoy the wallpaper and don't worry about the battery.
I also use pure black wallpapers for everything
Amoled displays save energy when using black Becuase each individual pixel has its own power source, and with black, it doesn't even light up
Yes. They sure are
-Sent from Tapatalk
depends on the lwp, some i would suspect are much worse than others on the battery,
look at the battery stats, should show how much.
the ones i use are very light on resources in 24 hours, battery use is .03% cpu 1min 31sec for the app itself.
Battery stats didn't show it. Changed to black and I am losing 1% an hour.
What about widgets? How much battery life do they consume?
I just added both The Android Central widget and the Connectedly widget to Nova Launcher. Curious as to how much more battery they will consume.
The only other widget I have going is Transparent Weather (which doesn't update often as I tend to keep location off most of the time).
Hey JS,
Where do you find the battery sipper LWP you mentioned?
Thanks
Oz
greenbelte22
