DO not disturb doesn’t work
  • Start date Start date
A
Android Central Question
I have the new Mate 20 Pro and the do not disturb feature doesn’t work. I have turned it on and I still have calls coming through. How can I fix this issue?
Have you made sure the "Interrupt for calls from my address book" isn't turned on. Ok, so its not called exactly that, but you get the idea.
Ok, its in "Define priority interruptions" in the "Do not disturb" menu, assuming that's the mode you have selected. In there you can say whether you want calls from all contacts, or favourites for example.
joelkmason
