do you think action memo and scrapbook will be synced with note 3 and note 10.1?
I think there's a great liklihood that the '14 Note 10.1's action memo and scrapbook will sync with the Note 3 but I'm doubtful about older Galaxy Notes.
I believe they are both essentially the same S-Notes on these two devices, so yeah, chances are pretty high that they will sync. Furthermore, I believe Sammy's partnered with Evernote this time around, so while probably not editable, you might be able to see those notes in your computer or Evernote account in older devices.
I tried out the Evernote sync on a Note 3 in-store model, and it works great. Hopefully it'll work the same way on the 10.1 2014 and Samsung might even be nice enough to give us older Note users that functionality too (2, 8.0, 10.1).
Did the Evernote sync let you edit any of the notes generated with the Note 3 or were they just 'read-only'? Are the 'actions' like video still playable?
I was able to edit the notes in SNote, and the changes synced back to the original note in Evernote. I didn't try to make any changes in Evernote on the web or a laptop. I don't even know if they allow you to edit handwritten notes on other platforms.
on the note3 it syncs straight away, in the background.
I'm thinking of getting a note 10.1 to replace my ipad 3 to go with my note3. I'm wondering if the s-notes will sync between the two, using evernote, and whether the note3 notes will show up as a small format, and the note10.1 notes will be scrollable?
I'm getting my Note 3 on Tuesday in addition to the 10.1 2014 edition that I have already. I'll be able to answer this soon
Come to find out there is a samsung app that syncs snote when you place them in proximity
I think the problem is that it's hot backing up for whatever reason. I've contacted samsung about it
Galaxy Note 3 - Galaxy Note 10.1 2014 Edition
I've had the GN10.1 for a day, and the GN3 for 2 weeks. The S-Notes sync very well via Samsung, but the action memos do *not* sync. They are separate and don't seem to be synced back to the Samsung servers. Oh, and I don't use Samsung for backup, just S-Note and Scrapbook sync (which also works well)
Evernote, independently of S-Note, syncs flawlessly between the two devices. I just don't use it as the S-Note sync.
how do you sync it? does it do it via the samsung option when you go into accounts?
That's correct: Go to Accounts, select your Samsung account, then tap on the name of the account (for me it's my email address). You'll see a series of sync options, including S Notes and Scrapbook. Do the same on the GN3, and you're good to go.
Nehasingh12
